She stranded me tonight...
1. 5 days ago she wouldn't start after being driven for 20 minutes. I let her sit for 5 minutes, she started again.
2. 100 miles goes by.
3. Tonight CEL comes on but she drives fine. I stop to grab something at the store, no start. Try the usual suspects; I put my ear to the fuel pump cover and it sounds 100% healthy.
4. Read the codes but it was a no code (1111). I'm pretty sure that can indicate Hall sensor.
5. Too cold for much more diagnosis.
Will have it towed to the shop tomorrow but any ideas? Maybe the damn Hall sensor again. This one is a strange one.
1111 is Control Module Malfunction. (B4)
4444 No DTC recognized.
0000 Display ends.
1231 Vehicle Speed Sensor.
2111 Engine Speed Sensor.
2112 Crankshaft Position Sensor.
2113 Camshaft Position Sensor.
2121 Closed Throttle Position Switch.
2212 Throttle Position Sensor.
2242 CO Fuel Trim Potentiometer.
2312 Engine Coolant Temperature Sensor [G62].
2142 Knock Sensor 1.
2342 Heated Oxygen Sensor 1 [G39].
2233 Mass Air Flow Sensor Reference Voltage.
2234 ECM Supply Voltage.
2141 Knock Sensor Control 1.
2143 Knock Sensor Control 2.
2341 Oxygen Sensor Control 1.
2144 Knock Sensor 2.
2324 Mass Air Flow Sensor.
2331 Oxygen Sensor Control 2.
2332 Heated Oxygen Sensor 2 [G108].
2411 EGR System.
4332 Ignition Output 1, 2, or 3.
4343 EVAP Canister Purge Regulator Valve [N80].
4411 Injector, Cylinder 1 [N30].
4412 Injector, Cylinder 2 [N31].
4413 Injector, Cylinder 3 [N32].
4414 Injector, Cylinder 4 [N33].
4421 Injector, Cylinder 5 [N83].
4422 Injector, Cylinder 6 [N84].
4431 Idle Air Control Valve [N71].
4432 EGR Vacuum Regulator Solenoid Valve.
1111 Control Module Malfunction.
0000 Display ends.
2411 EGR System.
4Driver4
17
09-05-2008 03:57 AM
SkinFlaps
09-24-2007 09:01 AM
Seabeast11
03-10-2007 05:06 PM
17593-oxygen (lambda) sensor- B2 S1 Internal resistance too high- intermittent. What does this mean?
I AM 2ks4
01-30-2005 01:30 PM
eventuallyblue
12-18-2004 03:59 PM
