So I applied 12v to the AC compressor clutch. I could see it move inwards but it didn't spin
Re: So I applied 12v to the AC compressor clutch. I could see it move inwards but it didn't spin
So you seen the clutch move inwards while the car was running and it didnt spin? Did it stall the engine or make the belt squeel? Try turning the clutch plate manually with the car off if it rotate then you most likely has a bad clutch. if it doesnt rotate at all then you may need a compressor and clutch. (note if its just the clutch you can get a clutch kit and not have to drain the system).
Evil Buddha
RS4 (B7 Platform) Discussion
07-05-2006 08:15 AM
