SOME SIMPLE STEREO WIRE IDENTIFICATION PLZZZ
Old 07-21-2012, 03:38 PM
saullyb's Avatar
Default SOME SIMPLE STEREO WIRE IDENTIFICATION PLZZZ
Hey guys!!
I have a 1990 Audi 90q and am replacing head unit
The wire harness has been cut for this decks that's already in here, and there are 4 wires.
2 white wires------antenna wires i believe
Brown--------------ground
Red/Blue-----------+12V ?
Gray/Brown---------???
Gray/Blue----------????
Can you identify me the Red/Blue, Gray/Brown, and Gray Blue wires please i would be very thankful.
Thank you
Old 07-21-2012, 06:42 PM
varia's Avatar
Originally Posted by saullyb
Hey guys!!
Thank you
get a cheap multi mete, makes life easier.
1990 Audi 90 Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Battery
Car Radio Accessory Switched 12v+ Wire: Red
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: White
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 3 1/2″
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Green/Black
Left Front Speaker Negative Wire (-): Orange/Green
Right Front Speaker Positive Wire (+): Green/Black
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 6 1/2″ Speakers
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): N/A
Left Rear Speaker Negative Wire (-): N/A
Right Rear Speaker Positive Wire (+): N/A
Right Rear Speaker Negative Wire (-): N/A
Old 07-21-2012, 08:40 PM
CRAZY_RUSSIAN's Avatar
here
http://12v.org/mods/index.php?include=stereo
good luck
Old 07-22-2012, 09:17 AM
Luxus Panzer's Avatar
1st post and YELLING AT EVERYONE =FAIL.
Old 07-22-2012, 06:44 PM
egp320i's Avatar
Who is yelling?
Rear wires are green and violet, left and right.
Both are have the same black negative wire as I have read.
Life would be made easier with splicing in a factory plug harness.
I bought a Scosche VW01B for cheap but it only has two plugs so unless you get creative it's not as plug as play as it should be.
The one I bought years ago which has 3 plugs I picked up at some radio specialist store, I have no idea what brand it was or if it even mentioned it.
Bit expensive but the one crutchfield sells would do the trick.
http://www.crutchfield.com/p_1207017...77#details-tab
<a href="http://tinypic.com?ref=23hocch" target="_blank"><img src="http://i50.tinypic.com/23hocch.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
In order to plug and play you would also have to purchase the reverse harness to replace the factory brown, black and red connectors.
Old 07-23-2012, 04:18 AM
Default THIS IS YELLING....CAN YOU HEAR ME NOW?
now my ears hurt
Old 07-23-2012, 07:16 AM
<B> HEY STOP YELLING</B>
Old 07-23-2012, 04:19 PM
varia's Avatar
Originally Posted by egp320i
Who is yelling?
caps lock = YELLING
Old 07-23-2012, 07:31 PM
saullyb's Avatar
Oh I'm sorry guysss, my bad on the caps thanks for all the replies though!
Anyways, "varia" I've already found that diagram but my wires just aren't that color though I have the 2 white ones connected to my decks antenna amp, the ground to the ground, and the red/blue to my constant on the deck... i have one wire left, check out this pic, the gray/blue one.
Btw right now my deck turns on, well it makes a little buzz and sounds like its ALIVEE, but the screen doesn't show anything, doesn't light up... takes CD's in n out though
Old 07-23-2012, 07:32 PM
saullyb's Avatar
The two white ones are hard to make out in the pic, it looks like a white band, I've just connected both of them to my antenna amp, which i feel is not right??
Quick Reply: SOME SIMPLE STEREO WIRE IDENTIFICATION PLZZZ
