spark plug removal
Does audi have a special tool for installing / removing spark plugs?
Or will a regular spark plug extention work?
I hear the wires are a pain to get off, any tips?
Thanks in advance
Thanks in advance
My car came with an Audi one - It is the handle of the wheel bolt spanner!
Dont know if this is the same for all Audis (mine has a DOHC head so the plugs are way down in) but I guess a normal extension is OK instead.
it should be, pull the wire
unscrew the plug
make sure the gap for the new plug is right
screw in the plug
plug back in the wire?
unscrew the plug
screw in the plug
<center><img src="http://www.permatex.com/images/catalog/lubricants/81343_80078_81464.jpg"></center><p>
Use an air compressor to blow out all the dirt down in the spark plug valley's, before removal, or all the dirt will fall down into the piston once the plug is removed.
Use "anti-seize" compound on the spark plug threads.
make SURE you use a locking extension. Otherwise when you try to pull the spark plug socket off the installed plug, you'll be left with just the extension and the socket stuck to the plug.
bubba j
10
10-25-2018 03:06 PM
4showa
08-03-2003 07:38 AM
