spring question
thats a rather broad question....miles??, whats been replaced suspension wise?
if nothing has been done and you're going to go threw the trouble of taking the struts out, you might as well do everything..tie rods,struts,strut mounts,control arm bushings, ball joints..etc etc.
Re: upper and lower control arms??? huh?
or somthing the thing that makes the wheels turn and the maybe their called a-arms i just know them as control arms for some reason
well there is no upper and lower control arms..there is left and right..
the best advice i could give you...is go to the site below, enter your car info, and go to Suspension, and replace anything you havent yet done.<ul><li><a href="https://www.autohausaz.com/index.html">https://www.autohausaz.com/index.html</a</li></ul>
So if I got all the suspension parts... looks under 400 dollars
Ball Joint Stabilizer/Sway Bar Link
Control Arm Bushing Strut Cartridge/Insert
Subframe/Differential Mount
Shock/Strut Mount
how many Hrs to fix ?..I wish I was a DIY guy
Shock/Strut Mount
Supercoupe
02-06-2007 05:33 PM
Regl
01-27-2005 03:46 PM
GrA8ful S8
04-01-2003 03:36 PM
