Starter install...
Starter install...
My starter died on my '88 90 10V, and I was wondering how to get to the other bolt.
I can get to the bottom bolt (it won't come off) but I can't see the other bolt(s). Anyone no where it is?
Also, the bolts are threaded the normal way, aren't they? Should they be torqued on. I don't have air tools, so I'm trying to get them off with a socket.
Any help is appreciated, maybe some of those cool pictures. My bently is not here yet.
Thanks
Aaron
Thanks
Aaron
the bottom bolt...
has a nut, that was what I meant, But it does not want to budge? I sprayed it with Lubricant, and it is soaking. How do I get to the top one? It seems blocked?
You can "IM" at JsnVR6Corrado.
I've only ever seen "bolts" on these Audi's...........
Maybe yours was modified by a previous owner?
See if you can see a bolt head on the other end, or feel a bolt head.
I've never seen a "stud" type of bolt?
That would make starter removel even more difficult.
Make sure you have the battery disconnected before you start removing too! It could be a "shocking" experience if battery not disconnected.
Correction..
Found the other end...Whew that was tough.
Now how do I get to the other one?
Had many shocking expieriences with cars. Know what to do now. Won't ever make same mistake again.
