Starter problem symptoms...
Battery is fully charged and the car started without a hitch two days ago. Battery is still showing 13 volts, but the car will crank one or two times and the volts drop dramatically. I even tried jumping it and it does the same the. Bad starter?
Does the car not even crank, as in you turn the key, big voltage drop and then nothing? Have you tried tapping the starter to get it to move and see if that helps? When my S4's battery finally called it quits it was VERY hard to jump start.
I've trying jumping it with another car and it does the same thing when being jumped. I'll take the battery in tomorrow, before I start taking anything else apart.
jloktalGst
05-30-2018 03:56 PM
dang
18
06-08-2008 04:21 PM
dragon-ryder
11
05-28-2005 06:16 AM
