Steering rack problems
I hit a big pothole with my B4 90 Quattro last week and bent a tie rod and damaged the steering damper. The shop has those items fixed but the steering rack seems to be moving not just side to side but slightly forward and backward. They claim that it's tight to the firewall so that seems to imply that something else is wrong. Any ideas? Do I need a new rack?
Oh yeah, it was also very low on fluid after the pothole incident, don't know if that could be the cause or effect of the steering rack problem.
All advice appreciated, thanks!
Get the front end of the car on jackstands and look at the rack while you have somebody else turn the steering wheel for you.
Chances are you damaged alot more than your front suspention. $$$$$!
I hit some crappy bumps too and now my stuff is all making noise like its loose. I checked the one side and couldnt find anything loose, maybe i better check more out soon.
good luck, hope we both dont have to spend mucho dollahs!!
Flipper ::sean1.8t::
11-05-2007 05:47 AM
shwndh
08-26-2006 07:14 PM
How many of you needed your steering rack replaced? How long should the steering rack last? There is
MarcDC
04-12-2005 07:48 PM
Beemer832
01-08-2005 03:19 PM
