Stuff for head gasket replacement . 90 cs 1993
So I'm working on a list for the impending head gasket job ( I'm pretty sure I need ). Some items are "might as well do"
HEAD
valve cover gasket; oil check valves; new head bolts; breaker bar; special head bolt sockets; cam locking or locating thingy?; cam shaft oil seals, front and rear; exhaust gasket; intake gasket; head gasket.
INTAKE MANIFOLD
IM valley gasket; oil check valves; IM gasket for the two seperate parts; allen wrench with whatever sized drive end.
FRONT OF ENGINE
timing belt; idler pulley; grooved belt; t-stat; waterpump; front main seal?; oh, t-stat housing and gasket?.
FLUIDS
degreaser; anti-freeze; distilled water; toyota engine assembly goo(wicked good stuff dude).
Oh and a crank locking pin...
What else?
P.S. not interested in porting and polishing or modifying stuff.
Thank you for investing your time.
HEAD
INTAKE MANIFOLD
FRONT OF ENGINE
FLUIDS
What else?
a seal & gasket "kit"?
Which contains all the seals you need, and is often less expensive...
Call Rod @ 1-800-472-1144. Tell'm "Mike" sent ya! ;O)
Blue book trade in value on my car is 2,300.00. Roughly. It is obvious that the strut mounts are shot and the exhaust needs attention there goes a couple bucks off the trade in value and if I were going to trade in the vehicle it is possible that they would find out about the head gasket problem plus I don't like to unload my problems onto others and I am also a horrible liar so after that I am left with what I paid for the tires and the new oil filter for a trade in value. In short I looked at the numbers and any new car that I could barely afford would not meet my standars for cars and going into hock for another older car that I would just have to go through again doesn't make sense to me after thinking about it. So I'll deal with what I have and do the best at maintaining and repairing the audi with intetions of driving it for awhile and keep my options open... P.S. I already have a bimmer. 1975 2002 that is in dire need of attention and purchasing a cheap new car would without a doubt keep money away from it and buying another older car (that I would enjoy driving 26,000 miles a year in) would take money and time so, ****, keep the audi and face the demads of car ownership.
dropping money on parts. Though I am pretty sure that this is going to happen. I think I'll get the water pump and tstat from some local guys. Thanks for the reccomendation. Which company would I be calling by the way?
rned
03-03-2005 08:37 AM
