Swapping the starter tomorrow...
I wish I had read this tip to remove the battery tray in my 1993 90CS because it was hard to do the way I did it without removing the battery tray. Should have looked here first,
Was the starter burned out from a bad ignition switch?
the starter itself looks pretty crusty so I figured I'd just replace the whole thing. If I can clean up the old starter I will. Core charge was fifty bucks
Car starts much better now. It's a good thing I decided to swap the starter instead of just cleaning it up. The bolt that holds the positive lead to the solenoid seized the nut and broke off, complete with a sizeable chunk of the solenoid casing.
Guess I won't be getting my core charge back.
93 90cs i read the achives but not much help, i have my manual but of course not much info on starter removal... NEED SOME HELP... how do i remove the engine mount, is this gonna make the engine fall out, where are the bolt to remove I found one, and have no clue how to reach it, and the other on is on the top and I know it is impossible to reach with out diggin around.... PLEASE HELP ME MASTER AUDI DRIVERS AND TECHS
<center><img src="http://pictureposter.audiworld.com/88819/emount.jpg"></center><p>
There's 3 bolts accessible from the pass. side wheel well and one nut on the top of the mount. I would support the tranny with a jack/jack stand that will hold the motor up. Don't forget to disconnect the battery!!!
biturbowagon
16
08-24-2006 01:36 PM
ltooz_a6_a8_q7
Audi 100 / A6 (C4 Platform)
12-06-2004 10:41 AM
coocoomike
07-01-2003 03:00 AM
