TB problems? Also MikTip question
Here's another question for people: has anyone that has put in a modified TB had problems when it first starts up? When I first start it up it will stall just about every time I let off the gas- it either hunts a little or revs just fall to 0 and it stalls. After it warms up a little it runs a little rough, but it still hunts a tiny bit. Has anyone else had this problem?
MikTip- where do you get that nifty special tool to remove/install the wheel bearing?
The special wheel bearing tool is a "Schaley" product.
Its the "older" version of bearing pullers.
There are newer, better versions out there by various manufacturers, but......
I've found the "hydraulic 20 ton press" method to work much better, and require less physical effort on your part! ;o)
The tool is nice to have, but then you will need 2 large wrenches as well, just to turn it!
All Z Time
13
11-05-2006 03:40 PM
TEB
09-05-2005 08:11 PM
