Tech Question: Engine Swap for a 1993 V6 90 Sedan
#13
Here's a couple that have been done
Mine
<IMG SRC="http://pictureposter.audiworld.com/57350/hoodpropped01.jpg">
<IMG SRC="http://pictureposter.audiworld.com/57350/hoodpropped02.jpg">
<IMG SRC="http://pictureposter.audiworld.com/57350/readytoroll.jpg">
And quattropat's
<IMG SRC="http://pictureposter.audiworld.com/56529/engbay.jpg">
<IMG SRC="http://pictureposter.audiworld.com/56529/pat_audi_1.jpg">
Mine
And quattropat's
#15
And that can be swapped out if you can't figure out how to use the stock AAN. But using the AAN intake is not that hard to do.
3B style intake
<IMG SRC="http://gallery.s-cars.org/albums/S2/aby_enginelhd.sized.jpg">
AAN intake
Oh Yeah, I put a 3B in my '95 also so I would know the differences. just the intake
<IMG SRC="http://pictureposter.audiworld.com/57350/mistake.jpg">
3B style intake
AAN intake
#16
Member
-There is a constant oil leak that the dealer was never able to fix.
-After starting the car, you start to drive away and the car seems to loose major amounts of power and then all of a sudden power burst and it goes. Then dies out again very quickly then burst again. It does it for about 2 minutes then its fine.
-Exhaust & Cat need to be replaced.
#17
-Find out where the oil leak is coming from... diagnose from there...
-Vacuum lines, throttle body, etc... get it checked out
-Because of exhaust leaks or just rust? Aftermarket system isn't too expensive...
dragon-ryder
04-06-2004 11:04 AM
Couper
10-22-2002 09:02 AM
Trio197
02-07-2002 01:17 PM
SilverCQ
9
02-03-2002 10:52 AM
