Is there any easy way to check my transmission oil level? How do I do it?
You have to remove the drivers side, inner CV joint heat-shield, to even see the 9-O'-clock fill plug! Then your car has to be level to get an accurite reading.
You need the correct sized tools to remove the heat-shield bolts & the fill plug.
Plus I take 'the shop' and its lift for granted alot.
Are the 90 heat shield bolts 3-10mm ones? Also, the socket for the drain plug is an inversed 19mm (IIRC).
At least it did on my '95 90S 5-speed this past weekend.
Have Allen wrench (L-shaped) for the bottom two and hex key socket ready for the top.
Avanthead
07-29-2007 08:48 PM
Avanthead
07-11-2007 05:12 AM
frankdome66us
04-14-2003 02:37 PM
Åüdios69
07-10-2002 10:46 AM
