Are there any other bolt patterns or offsets that fit?
I have a '89 90Q looking for 17's. What tire would I run with those? 45/17 I hope, Ok my bolt pattern is 4x108, not sure of my offset. Little help here, and what offset wheels will fit with the 4x108 bolt pattern?
Thanks,
Anthony '89 90Q
Thanks,
Anthony '89 90Q
...only way to change the bolt pattern on the car is to swap hubs for the bolt pattern you want OR as some have discussed have the wheels re-drilled to 4x108.
4x108 is the only bolt pattern that will work on stock B3/B4/CQ/Cabrios (US Spec).
However the S2 in Europe is 37mm offset/5x112 and
the RS2 is 55mm or 51.3mm offset/5x130
The higher the offset the further in the wheel will sit, the lower it is the further out the wheel will sit (IE. 45mm on the B3 sits further in than 37mm on the CQ/B4/Cab).
mktt
Wheels & Tires Discussion
06-09-2009 12:26 PM
Sarge
Audi R8
09-25-2007 09:53 PM
Jack Wang
03-06-2001 02:22 PM
