are these spark plug wires too big for a stock 91 cq?
which kind of spark plugs to get? ngk or bosch? should i get the dis cap and rotor from the dealer?<ul><li><a href="http://72.3.236.181/Magnecor_Spark_Plug_Wire_Set_Audi_1989_1992_5_Cyli nder_20_Valve_Non_Turbo_Engines_%28only_7A_series_ engines%29_5Cyl_7mm_Ignition_Cables_%28Black%29-p31517.html">found these during a search</a></li></ul>
Get the correct 3-electrode Bosch F6DTC spark plugs. Distributor cap and rotor can be had from any internet WorldPac distributor much cheaper than dealer.
i was there today and they told me you cant buy them as a set
( whats the part # for the plugs? best place to buy them? online or az, advance auto, napa, etc? buying parts from the dealer is hazzardous (sp?) to your health!
![Embarrassment](https://www.audiworld.com/forums/images/smilies/redface.gif)
$121.18 for a set of spark (bosch) plug wires, $3.08/spark plug, $18.68 for dis cap, $4.22 for dis rotor. so looks like $159.48 for everything. is there anything else to buy for a tune up?
Define lots. I heard 2-3 complain on 20v.org, and then at least that many say they had good luck with them. I had good luck with both sets (KV85 and 8mm). The BIGGEST thing with the Magnacores is making sure they can't rub on things, as the silicone casing is a big fragile when compared to the 7mm vinyl covered wires.
