For those of you who have added the auxiliary gauges what oil pressure sender did you use?
Old 02-18-2004, 06:38 AM
Junior Member
Jaredg's Avatar
Default For those of you who have added the auxiliary gauges what oil pressure sender did you use?
Currently I am using PN 035 919 561A which works fine for the guage but causes the idiot light to throw.
Any ideas what the correct one is?
Old 02-18-2004, 06:39 AM
Brdman*'s Avatar
Did you plug in both wires?
Old 02-18-2004, 06:40 AM
Brdman*'s Avatar
Default Re: Did you plug in both wires?
<ul><li><a href="http://www.mnsi.net/~natwhite/Audi/auxgauge.htm">http://www.mnsi.net/~natwhite/Audi/auxgauge.htm</a</li></ul>
Old 02-18-2004, 06:48 AM
Junior Member
Jaredg's Avatar
Default hmm the way that mine was setup the factory
<center><img src="http://www.mnsi.net/~natwhite/Audi/Images/v6block.jpg"></center><p>The oil pressure sensor for the oil pressure warning system was in the same location as the oil pressure sender for gauge in the picture. I suppose I need to add the oil pressure sensor for the oil warning system on the opposite side of the T in the block so it would sit underneath the air conditioning compressor??
Old 02-18-2004, 06:51 AM
zeems's Avatar
Does your new Oil Pressure Sender have 2 prongs?
Old 02-18-2004, 06:58 AM
Junior Member
Jaredg's Avatar
Default Yup
When the line for the oil pressure sensor for the oil pressure warning system is hooked to it it throws the wrong signal and the idiot light displays.
Old 02-18-2004, 07:02 AM
zeems's Avatar
Ok, so switch the wires on the sender around.
Old 02-18-2004, 07:41 AM
Junior Member
Jaredg's Avatar
no dice
Old 02-18-2004, 08:13 AM
zeems's Avatar
Check your oil???
Old 02-18-2004, 08:14 AM
Junior Member
Jaredg's Avatar
umm oil is fine thanks
Quick Reply: For those of you who have added the auxiliary gauges what oil pressure sender did you use?
