three spoke wheel in a coupe q?
#21
Coupes have a rear window wiper - I need to consider the wiper AND the autocheck
B4 90s don't typically AFAK have the autocheck
My late 91 Coupe ( airbags, moonroof ) does...
#22
<ul><li><a href="http://picasaweb.google.com/cvaladez/UrSWheelHornModificationAudiB4?feat=directlink">ht tp://picasaweb.google.com/cvaladez/UrSWheelHornModificationAudiB4?feat=directlink</a</li></ul>
#23
If I could centralize the info, and get some photos together, then I could crank out a sort of 3rd-party how-to, submit it to Kris Hansen (AW Tech Editor) for publication in the Tech section.
He might go for it if it's polished and pictorial.
I have no problem putting such a thing together, but having knowledge is #1.
This would be for a B3 application, and I would discuss both sedan and CQ if I can get info for both.
#24
It'll still work just fine.
The rear wiper is another story. If you want the "push to the rear for rear wipe/wash", I don't think that's going to happen.
But there is a workaround for the rear wiper.
#27
you'll need the column covers from a 95 90 as they have the recess for the clock spring. You'll probably need to trim off the turn signal canceling tab off the sport wheel and epoxy on one from an older non airbag wheel(see the s4 sport wheel conversion link) Notching the lower cover for the hazard switch is probably necessary too. That's what I did on my 200 20v but used the s6 column covers, but I plan on getting a set from 95 90 to make it look more factory.<ul><li><a href="http://www.s-cars.org/postnuke/modules.php?op=modload&name=Downloads&file =index&req=viewdownloaddetails&lid=53& ttitle=UrS4_Sport_Steering_Wheel_Conversion_Instal lation">http://www.s-cars.org/postnuke/modules.php?o
