throttle potentiameter code comming up
seen a car with that code turned out to be that someone tried to adjust the idle by adjusting the throttle plates causing the sensor not to close. So check to see if when you close yur throttle that you can here the switch click
ricekikr
10-29-2010 05:23 AM
JazzGuitarist
01-17-2007 04:33 AM
