Throttle Potentiometer ????? HELP
Help, i have to go on a trip and here is my problem. I have a little rought idle, when i hold the car at a constant rpm the engine stutters. When i push full throttle its fine. What could the problem be?
Your coupe is digifant - has no potentiameter IIRC.
Maybe check codes?
So It's studdering under idle and part-throttle, but not when you rev it? When's the last time the basic plugs/cap/rotor have been done? Check those, could maybe be an injector problem? I'm just shooting off ideas on that one.
Maybe check codes?
wires plugs cap rotor less than 5 months old.
if the 20v coupe engine dosent have a throttle potetiometer, how does it know throttle position?
thanks
dave
thanks
dave
Well I thought it had a TPS, but now that I look it lists a potentiameter. Really, I'm the last guy to ask, I don't know much on the 20V digifant. I figured it was a TPS type system, but I guess not. So yes, I'm totally wrong. Hopefully someone else can help you more on this one, I'm not much help :-(
Not a throttle potentiometer. If the car runs fine, but when you come to a stop it dies, it is probably the idle switch.
On the early 90 coupes the idle switch and potentiometer were two separte items. On the later 90 coupes they we combined. This is unfortunate, because the combined unit is about 200 dollars.
Check out the site I have attached. It gives a procedure for checking out the unit with a Multimeter. Don't have one. Buy one. Cheap and can be used to track a lot of headaches.<ul><li><a href="http://20v.org/throttle.htm">http://20v.org/throttle.htm</a</li></ul>
phil.krasko
NorCal Discussion
09-09-2008 11:56 PM
sk88erguy
Audi Original "S" Cars
03-07-2006 05:20 PM
