Timing belt - What they don't tell you
#11
In addition to my last post/reply, I think that shoe broke off when I turned the exhaust cam back counter clockwise after it popped clockwise out of position while I was fumbling around with other things and bumped it.
#12
It sounds like you're getting it figured out. Good! I don't think you could have caused much damage cranking over by hand. And... I'm unable to answer your questions about the CCT as I don't have experience with the 30v engine. Someone else here will surely know!
That is an interesting video! The borescope/endoscope is a nice tool to have, right? I had recently bought one and have found it so useful!
#13
#14
The borescope came with a 90 degree adapter which barely works at all though. I'm trying to find, or make one that works better. A 180 degree adapter would be even better for looking up and back at valves and such. I wonder if such a thing even exists.
#15
I really like the one that I'd purchased from Amazon. Depstech Dual Lens. The camera can look in either or both directions at once. You can turn the light up very bright, if needed. It's great for videos, too.
I had thought that I'd dropped a piece of broken head bolt socket down the oil passageway recently and was able to cope all the way down into the crankcase past the crankshaft. I couldn't find it.
#16
Good to see all the advice and comments. For what it’s worth, having done the job myself, the main learning was take out the front panel and rad because it’s great for an all access clean up .. and.. fit the right camshaft sprocket bolts.. I’m really grateful for earlier advice on getting the right bolts and torque for these ( more than one bolt option) and to be honest I’ve never been so careful with a torque wrench until I did this job .. all thanks to earlier advice on this forum.
#17
I had either the tool or the CCT strip out while it was compressed while I was busy getting the intake cam out. It won't thread in further, or thread out, so the bolt is either "waisted" now, or the threads on the tensioner are just gone and gripping it, or both. Whatever happened, I have a new tensioner ordered now. I'll probably be able to get it out without the tensioner fully compressed, just a bit more of a wrestling match while taking care not to ding anything.
I was considering fabbing some kind of a long reach tapparatus (get it?) to put some 1/4-20 threads into the tab on the bottom of the CCT where the tool threaded into, and thread a 1/4-20 piece of rod stock into that and put the plastic part of the tool over that to compress the CCT from the top via a nut on the rod stock. But that would possibly make a bigger mess than I could clean up with the head on the car and the limited amount of space in which to work. I opted for a new CCT.
I still need accurate information regarding the cam chain timing marks on bank 1 (passenger side) and roller counts between.
I used to have a mill and a lathe in my living room, that's why my ex-wife divorced me I think...But I sure wish I still had the, cuz this **** woulda been long done and finished. I woulda just made the tool, and it wouldn't have failed like this cheap garbage I bought did.
And I repeat:I still need accurate information regarding the cam chain timing marks on bank 1 (passenger side) and roller counts between.
N'Syncro
33
02-16-2020 03:12 PM
LaserSVT
64
01-19-2016 04:26 PM
Audi A4 2002 S4 6spd 98k
rsixxer23
01-06-2016 03:25 AM
stormchaser1967
09-02-2015 12:47 PM
