timming belt advice
timming belt advice
we all know i am not the most confdent in my timming belt ablities. is this right? line up the fly wheel timing mark in the window where i can see it. make sure the rotor is lined up with the notch on the dist. and make sure the dot on the back side of the cam gear is lined up with the valve cover? just dont want ot screw this heaD UP. thanks every one!
You have to get the intermediate shaft lined up too...
...cam, crank, then set the distributor to TDC.
Don't forget to tension the belt either ;o)
About to do timing belt, is a pully puller needed or can I crack the cam pullys with a screw driver?
picnicbob
30v V6 Discussion
01-19-2006 04:34 PM
