Tips for removing motor mount
Anybody have a good method for removing the center bolt from the passenger side motor mount on a 95 90Q?
I'm replacing the starter, but I would like to remove the motor mount without destroying it. When I turn the nut, the entire stud turns with the bushing in the lower part of the mount.
I tried jacking the motor up/down, prying up/down, clamping the metal washer (in between the upper and lower parts) with vice-grips. Nothing seems to work.
I could probably tear into the rubber boot and clamp there, but I would like to not destroy it. I'm hoping someone on here has a good trick for this......
<a href="http://s300.photobucket.com/albums/nn34/2lss/?action=view&current=audi_motor_mount.png" target="_blank"><img src="http://i300.photobucket.com/albums/nn34/2lss/audi_motor_mount.png" border="0" alt="audi motor mount, passenger side motor mount"></a>
Well that sucks. I was hoping that wouldn't be the case.
Anyway, it looks like I have to buy the entire mount (aluminum block + the bushing) for around $70. Is there a cheaper solution? i.e. just buy the bushing and press it into the old block?
RallyVermont
09-24-2008 06:49 AM
GinsterCoupe
10-20-2005 07:30 AM
TwentyValveB5+S4
10-15-2005 01:35 PM
VAP
11
04-03-2005 01:58 PM
