Tranny filling question
Can someone tell me, when changing the transmission fluid (5spd, 93 90CSQ), do you only fill by the inner CV joint plug, behind the heat shield. There's also that part of the transmission which is attached (between the transmission and where the drive shaft hooks up ?), does that have a drain and fill as well. Sorry for my lack af tranny terminology. Thanks in advance for any help.
The rear section is called the rear differential.. or rear diff.
yep,that needs to be filled to.
Are you draining everything and then filling it up?
Do you know the specs?
Nick
Nick
The transmission housing includes the gearbox, the front diff and the center (torsen) diff. There is only one full hole for all three components, as you've located.
Black Sunshine
05-14-2006 07:09 PM
sk88erguy
Audi Original "S" Cars
02-14-2006 08:54 PM
sk88erguy
12
02-04-2006 03:08 PM
DM-S4
09-01-2004 12:34 AM
WoostaS4
01-27-2003 06:45 AM
