Tranny Fluid Change...
Hello all, ive got a tranny fluid change for my 93 90s slated for this weekend, Ive ordered a filter change kit from http://www.alloemaudiparts.com which includes the filter and pan gasket. Now I was reviewing the specs on www.12v.org, and noticed that there is also some final drive fluid which needs to be replaced. I did some quick searching on the car, and found where to pour in new tranny fluid (red dip stick back right of motor) and found that fluid drain plug, but i am unable to find where to drain/fill the final drive fluid. Anyone who has changed their tranny fluid, could you please help.
Final drive (differential) gear oil plug is typically located on the side of the tranny, near the...
CV joints (where the front drive axles are attached). There may or may not be a drain plug, on the bottom, for the differential.
TerminA8r
01-16-2006 12:43 PM
CLeonard
03-29-2004 05:12 AM
kaynos
08-28-2003 05:38 AM
