Turn Signals Stopped Working
Old 04-09-2010, 06:52 AM
  #11
dtompsett's Avatar
Check the actual fuse connections... (how I know)...
My 90q had the turn signals and wipers quit one night. Next day was a 1000km drive home... in the rain. Following weekend I tore everything apart... testing continuity, swapping spares, etc etc... nothing seemed to work. Occasionally the wipers would function, signals would kick on, etc...
In my frustration, I had shut off the lights in the shop (switch was right beside the fuse box), and the wipers tried to cycle... and I spotted the arc.
Fuse was fine... the little connectors in the fuse box has seperated and weren't making contact. HOURS AND HOURS of diagnosing/testing/swapping... 20 seconds to pull the fuse, grab a small flathead screwdriver, bend the contacts in the fuse box, and reinsert the fuse. worked fine.
Still working to this day... 5 years later.
No ignition switch replaced. No turn signal stalk replaced. No relays replaced.
Old 04-10-2010, 01:00 PM
  #12
Obscura's Avatar
Originally Posted by CRAZY_RUSSIAN
if it has not bean replaced before, you have paint over the two screws. you need a really small flat head to remove the bolts, get some sort of light in there ;-)
Yes I removed those 2 screws and it still wont budge. Is there something else I should remove?
Old 04-11-2010, 01:52 AM
  #13
maineman's Avatar
There are some photos in this thread that may help you
https://www.audiworld.com/forums/sho...166571&page=10
Old 04-15-2010, 04:16 PM
  #14
Obscura's Avatar
The ignition switch was cracked an melted. Pretty sure faulty trunk wiring is causing the wiper/signal fuse to blow, and will mess up the new switch as well I'm sure. Had it all working for about 2 seconds. Time to to get working on the wiring...
A4wheelin
01-23-2008 04:33 PM
lrrr
11-22-2007 06:30 PM
OCDboy
08-30-2007 12:21 PM
audijim113
Audi 100 / A6 (C4 Platform)
01-05-2006 10:52 PM
Quick Reply: Turn Signals Stopped Working
