Universal O2 Sensor
Someone did a write-up on universal oxygen sensors and bad gas mileage recently
I think it was repeater but I am not too sure.
Anyways, it boiled down to almost and extra 30-40 miles per fillup he lost while using the universals.
No quite. He used a 13913 and called it a universal. The 13913 is NOT a universal.
It's an OEM O2 sensor for a completely different car. Many people have found that it works fine after you clip the OEM connector off. I don't know of anyone who has used the universal sensor that Bosch actually recommends. Now that would be interesting...
Hmmmm... but I think that the universal sensor that Bosch reccomends is the same as OEM
but without the connectors. If it's not the same spec they would not recommend it. That being said I have not had a problem with the 13913 or the NGK 4 wire I am using now.
Yes, but it doesn't have the OEM connector. That means either soldering or crimping >>>
which can mean trouble if not done properly.....
I've sucked up more than my fair share of solder flux fumes over the years, I can say with a high degree of certainty that performing high reliability solder joins is part art and part skill, not unlike watchmaking.....
In my experience it's a whole lot easier (granted more expensive) to use an OEM sensor for such a critical, low voltage and low current sensor....
webster
Audi 100 / A6 (C4 Platform)
06-19-2007 06:33 PM
CK NYoC
12v V6 Discussion
12-28-2005 02:54 PM
GlasSman
9
12-08-2005 08:25 AM
repeater
Audi Original "S" Cars
04-03-2005 12:33 PM
