upgrades...
upgrades...
i have just gotten word that my car will be runnin by friday. i am going to start doing some small stuff to it. any ideas? i want to get more powerful coil/wires/plugs. does that help much? do i need better distributor cap too? are there any intake upgrades for audi's? thanks for any help.
Coil is not a weak point on these cars.
Just replace the cap with a new factory piece, along with the rotor and plugs (Bosch W7DTC, triple electrode coppers). Wires, stock are more than adequate for most things, otherwise look at Magnecore's 7 and 8mm wire sets. The 8.5mm and 10mm are totally overkill.
If you can find a Jamex (ya-mex) lower air filter housing, that'd eliminate that spot of restriction (it is an aluminum frame with a triple layer foam open element filter). Or, just remove the warm-air inlet crap and duct the opening forward.
Biggest thing you can do cheaply and easily is a cam, Blau's 272 is reportedly not as aggressive as most other 272 cams (Elgin, Schrick, etc), so it won't give a lopey idle, but also won't gain quite as much as the others. After that, do an exhaust from the cat back. No larger than a 2.5" pipe. Beyond that, you'd have to pull the head and manifolds and have them worked on.
go to my website...........
i had my old audi done up pretty nice look at the mods page.
www.geocities.com/audi2l/index.html
i am right now working on an intake system i will let you know how it goes.<ul><li><a href="http://www.geocities.com/audi2l/index.html">www.geocities.com/audi2l/index.html</a></li></ul>
also
i use bosch +4 spark plugs they help alot belive it or not, port and polish the head and exhaust allways helps. some cool stuff are a short shifter helps you shift quicker!
Mr Paul [T-28]
12v V6 Discussion
05-07-2005 09:46 PM
