vacuum lines ('93-90)- not shown in bentley's
above and to the right of the brake booster there is a vacuum check valve. the main line that leads to thae valve originates through the driver side fender wall. my qestion is what lines attach to the points before and after this valve? there is a larger black vacuum line attached to the point after(end)the valve, but i do not know where it terminates. also, where does the vacuum line that controls the fresh air vent(a/c)terminate under the hood?
bentley does not show these lines. any help would be appreciated. thanks!
That is the check valve and vacum resevoir bottle (inside the fender) for the vac supply to the.....
heating / AC controls. You are right, it is really not shown anywhere. That black and yellow plastic check valve often cracks and leaks where the smaller line connects.
reefer_bob
07-01-2006 09:34 PM
CharlieGSanD
09-29-2000 12:30 PM
