valve seals
I have to take the valve cover off to replace the valve cover gasket of my 20v, thought I may replace the valve seals while I'm at it. Consulted the Bentley, discovered the recommended usage of a number of special VAG tools for the job... Not having these tools, I was wondering if anyone has suggestions for doing it sans special tools, or if anyone in the Baltimore area had some tools they wouldn't mind lending out.
the special tools.
Requires both cams to be removed, and often requires the head to come off the engine....<ul><li><a href="https://forums.audiworld.com/9080/msgs/192813.phtml">https://forums.audiworld.com/9080/msgs/192813.phtml</a</li></ul>
No Bozos!
In either case you at least need the spring compressor. If the valves are sealing well and you can build up good compression in the cylinder then if you're lucky you can do it while on the car. You may end up pushing a vlave down, and then the game is over and the head must come off.
It's much easier with the head on the bench.
crank piston down, run a few feet on soft nylon rope into the spark plug hole, crank piston back up tight. Don't forget to remove the rope when done!
I have a head to practice on. How do I gorilla the valve spring retainer off to change the stem seal
PartyBoyRacing
10
08-05-2008 05:29 PM
|skolnick
Audi Original "S" Cars
9
04-09-2007 01:09 PM
