Washer fluid tank
As i attempted to refill my windsheild washer fluid today, i noticed that it was dripping from the front bottom of my driver's side wheel well. I'm thinkin maybe the tank has a crack in it, because the leak was relative to that of a dripping faucet. And what makes it worse is that i cant get to the tank to work my duct tape wonders, nor can i even see where the tank is. This ever happen to anyone? Or at least, do you know how to get to the tank? TIA
<center><img src="http://pictureposter.audiworld.com/46492/pc060005.jpg"></center><p>You will need to remove the cover for the bottom of the engine.. pic shows where it is
You will need to remove the drivers side front tire. Then remove the plastic inner fender liner! BTDT! Twice! ;o)
You do not "have-to" remove the lower cover, but......
I had to patch mine twice so far!
To date the glue is holding, with "No leaks"! :O)
The washer fluid pumps go bad a lot of the time. It very well could be the pump. They are a bitch to get to...but they are in front of the Left front wheel housing (bottom)...Good luck
forcefedfreak
11-19-2007 08:32 AM
Shep 1.8T
12-19-2006 06:02 AM
p3u
07-11-2005 03:46 AM
UrSoccer_mobileĀ®
10-09-2002 12:03 PM
