What can I get for my 1990 Coupe Quattro?
<center><img src="http://pictureposter.audiworld.com/83837/mycouperf.jpg"></center><p>1990 Audi Coupe
Pearl
181K Miles
Purchased 2/03 w/ 151K Miles.
Repair history.
Prior owner replaced:
fuel lines
Brake Rotors
Brake Pads
Timing Belt & Water Pump
Repairs I have made since the purchase:
Suspension
New control arm bushings
Front strut mounts, cartridges, bushings, bellows, dust sleeves
Front Tie Rod Assemblies
Right Rear Ball Joint
Right front ball joint
Rear sway Bar Links
Left Front Outer CV Boot
Control Arm Bushings
All four struts
Power Steering Pump
Right Front Outer CV Boot
Body
Euro headlights
Air Conditioner compressor, condenser, Receiver Dryer
Engine
Timing Belt & Water Pump 150,000 Miles
Multi-function switch
Thermo fan switch
Fuel filter
Oxygen Sensor
Fuel Injectors (1 twice)
Spark plugs
Plug wires
Cooling fan
Thermostat
Transmission mounts
Catalytic converter
Distributor Cap and Rotor
Engine Mounts
Crankcase Breather Hose
Fuel Pump
Air Mass Meter
Coolant Temperature Sensor
Air filter
Fuel Pump
Distributor
Brakes
Replace rear brake calipers
Emergency brake cables
Stereo
Alpine MP3 Player
Infinity speakers, front and rear
MTX Thunder Amplifier
10” Alpine Sub
Wheels/Tires
Original Speedlines/Michelin Mud & Snows
17" Panthers/Toyo Proxes
Pearl
181K Miles
Repair history.
fuel lines
Brake Rotors
Brake Pads
Suspension
Rear sway Bar Links
All four struts
Power Steering Pump
Body
Euro headlights
Engine
Thermo fan switch
Fuel filter
Oxygen Sensor
Spark plugs
Plug wires
Cooling fan
Thermostat
Transmission mounts
Catalytic converter
Engine Mounts
Fuel Pump
Air Mass Meter
Air filter
Fuel Pump
Distributor
Brakes
Stereo
Alpine MP3 Player
10” Alpine Sub
Wheels/Tires
and in the high 100K range in miles, yeah I'd say $4500-5000 tops. If you're not in a hurry to sell I'd start listing it at $5k, work your way down if nobody shows interest.
I'd pay lots more for a car that has maintenance records than one with out. That being said, I bought my UrS4 with NO records except for a receipt for the big brake kit, which I could obviously see existed.
Just like a house - people pay more for a well-maintained house compared to a similar home in poorer condition. Some deferred maintenance will help cure that obsolecense, but it does not "add" value - it will only bring the price closer to what the market will bear.
With a car, a well-maintained vehicle in excellent condition can bring the top scale of what's listed in the NADA or KBB. There are exceptions, no doubt, that affect the price like where the car has resided, vehicle history report, etc. But maintenance history doesn't add any value to the car.
Xel
11
12-31-2006 09:20 AM
loanshark
16
12-17-2001 09:10 PM
