what are the chances...
how old are the bolts? usually they are "use once and destroy," but there may be a spec given in Bentley for re-use parameters.
yours are different than mine, so i can't answer the question completely.
Howdy! The head bolts are stretch bolts, once they are torqued it's all over for them. You'll notice that the torquing procedure has a finish with a 1/4 turn, if I remember correctly off hand. This means you reach a torque level, then when you finish with the 1/4 turn the threads reach their designed stress limit, thus they "stretch." This is done so all the bolts get even torque. Whenever you see a torque spec that involves a finishing with a 1/4 turn you're dealing with a stretch bolt.
Cheers,
Cheers,
Luxus Panzer
12v V6 Discussion
09-30-2006 05:49 PM
pro_mtn_biker
12-25-2003 06:46 PM
Mirror|rorriM
11-05-2001 03:41 PM
