What is a tie rod? What does it do? Apparently mine is "frozen"
Which means heat is required to release the nut on the tie rod ends - the part that controls alignment/tracking.
Too much heat and the grease in the ball joint can deteriorate meaning new tie-rod ends which are usually not that an expensive part BTDT!
<center><img src="http://pictureposter.audiworld.com/41300/tie_rod.jpg"></center><p>It connects your rack-and-pinion steering to your struts. Usually the tie rod end seizes inside the tie rod itself and they have to heat it up and break it to get it out.
Tourette(AFC2.812v)
10-01-2006 02:06 PM
audi2.7audi
10-07-2005 04:19 AM
ahaiceman
09-08-2005 03:43 AM
