What is the trick to get the ball joint out of the hub...
Old 04-12-2003, 04:56 AM
computrtutr's Avatar
Default What is the trick to get the ball joint out of the hub...
on my 93 90S? My car is a little different from the one in the tech section. There is a vertical lin behind the hub. I removed that, then removed the thumb bolt. the ball joint is stuck in there as firm as ever... I had them replaced a few months ago. How do I get it out (To avoid needing an alignment)? This is for a CV replacement. Thanks everyone, you've all been a big help!
Old 04-12-2003, 05:18 AM
Tried prying open the clamp to the thumb- didn't work.
Old 04-12-2003, 05:25 AM
Will a ball joint fork destroy the joint?
Old 04-12-2003, 05:34 AM
Junior Member
Mr. fix-it's Avatar
Default Re: What is the trick to get the ball joint out of the hub...
Have you removed the control arms from the sub frame? If so you dont need to remove the ball joint. Just remove the strut link and you should have enough play to remove the axle. Yes you will probably destroy the ball joint if you use a pigs foot separator.
Old 04-12-2003, 06:08 AM
Default figured another way...
remove the two bolts at the top of the hub, manipulate the CV out, and put one back thru its hole. Thanks for everything!
Old 04-12-2003, 08:40 AM
Tech Guru
4Driver4's Avatar
Yep. Well, just the boot, but the dirt will do the rest.
Old 04-12-2003, 08:42 AM
Tech Guru
4Driver4's Avatar
Default You may have changed the camber.
I'd watch for tire wear.
I usually use a bar to pry down on the control arm with steady pressure, then tap the control arm downward with a hammer.
2001s4loored
10
11-07-2008 07:42 PM
Mark P
07-05-2006 12:14 PM
Kyle K: TampaS4
29
11-01-2004 06:18 AM
egp320i
04-12-2004 06:18 PM
escargot
Audi Original "S" Cars
12-26-2003 01:58 PM
Quick Reply: What is the trick to get the ball joint out of the hub...
