whats the first thing to test after finding no spark but good coils?
We tested under the coils and got 12 volts at them. i heard mention of a crack sensor... is that next?
Cam Position Sensor - F6010-55220
Ignition Timing Sensor- F6010-157603
Crank Position Sensor - F6010-56930
These are worldpac part numbers. Go to importec.com, or similar to order. Assuming you have a 12V V6.
You can also use it to check for ideas as to what could be going wrong.
In your post you said crack sensor. I think you mean either the Knock sensor or crank shaft sensor? I believe the Knock sensor efects spark. I know the Fuel pump relay can effect spark.
Cryptic1911
10-25-2004 11:38 AM
Wren90q
11
06-05-2003 05:07 AM
Jeff Doble
10-01-2002 04:59 PM
