what's the substance used on the ABS sensors... is it white grease? if not, what is it?
When I took the ABS sensor out, it was coated with some transparent/white solid greasy stuff... I'm assuming it's just white grease, but if it isn't, could someone tell me what it is. TIA!
<center><img src="http://www.royalenfieldusa.com/gz/images/PrmtxDielectricGreaseZ90874.jpg"></center><p>If I remember correctly it's dielectric grease
if you took the sensors out, most likely the system won't work properly when you reassemble cause one will be slightly mis-aligned. I end up disabling the ABS on all my 90q's anyways... it's pretty oldschool... doesn't work well.
And the reason I have a red car with a black hood...
dad got the car safetied, drove it 500m up the street to the licensing office... and when we went to stop, the ABS kicked in and he rear-ended a truck. Had to steal the hood, latch support, and passenger headlight, off of my old black 90q parts car. A day later, I pulled out the ABS relay completely.
<center><img src="http://pictureposter.audiworld.com/9207/abs_dirty_sensor.jpg"></center><p>and have everything stick to it thusly....
For the moment, I just used some brake clean and wiped off the old grease, but the bugs are coming out so I'll stop here for tonight. Next time I can get under the car, I'll put the new caps on, grease those babies up (with a thin coat of grease :P) and pop them back in.
