Where to Buy Rear UPPER Control Arm Bushings '95 90q? Found Trailing Arm and ower, but not upper.
Thank you in advance! I have been searching for hours with a Slllloooowwwww dial-up connection and I can't find the two upper control arm bushings, just the trailing arm and lower bushings. Blau sells a kit for $229, but I currently don't need all of them.
If anyone has a source, I'd sure appreciate it.
Item Number MSRP Core Price Price
8D0505185A $22.25 $0.00 $15.35
Rear suspension - Upper control arm - Bushings
Bushings, a4, inner - a4 w/quattro (1996-01), s4 (2000-02) 1996 - 2001
Add to Cart Contact Us
could not locate B4 bushings, p/n is similar 8A0 505 185 A, could call and ask em.. or A4 might fit just fine
lower bushings are $15 as well. blau is just expensive<ul><li><a href="http://www.genuinevwaudiparts.com/partlocator/index.cfm?siteid=214407">http://www.genuinevwaudiparts.com/partlocator/index.cfm?siteid=214407</a</li></ul>
I got mine from world impex but they are around..
Here is the part numbers I used.
Inner (need two per side)
8a0505185a
outer (need one per side and it's a b!tch to change)
8a0505172b
8a0505185a
8a0505172b
QPower95
15
06-10-2010 01:55 PM
ThirdEye
05-18-2003 03:52 PM
fidget
06-28-2002 10:50 AM
