Where is the clutch slave hiding?
I was trying to determine if the clutch master or slave was bad, and since the master was not leaking I tried to find the slave, but am not sure if I found it or not. Is it located above the catalytic converter and sits above the trans housing in a little tunnel area or is that just part of the trans? Can't find anything else that even resembles the slave underneath the car so far... Where's it hiding? This is for a 90' 80 non quattro. Thanks.
Steve
Steve
you might just have to get under the car again. try using a flashlight this time round. It should be on the drivers side, if you need to find it for more confirmation,just follow the lines from the brake cylinder all the way to the tranny most likely you will find it. You should be able to see the slave bleeder once you are under the car.just feel around for it, thats if you know what it looks like.
any stg3 clutch kits available for the coupe quattro 01a tranny code?stfa and cant find anything for
Turk@Ssptuning
08-23-2007 06:20 PM
M power this!
08-10-2007 09:30 PM
Anyone remember the metal clutch slave cylinder part # . . . I thought I posted it but can't find it
Jeff Vader - boscoj
11
03-07-2005 02:24 PM
90quattroman
08-13-2001 02:22 AM
