where to find a 3b harness , and how much could it be ?
i'm trying to get a better understanding of the wiring process i'll get into.
for a 10Vturbo i was told i need a 3b wiring harness .. is that correct ?
can i make the 88 90q harness to work ..or there is too much work involved that way ?
Thanks !
Thanks !
If you're using an MC 10vt engine.
MC1 engine with a lower compression ratio, K26 turbo, single knock sensor, and a MAC-11 ecu was in the 86-88 5kt and 5ktq as well as some of the early 89 200's and 200q's.
MC2 engine with a higher compression ratio, K24 turbo, dual knock sensors, and a MAC-14 ecu was in the 89.5-91 200 and 89.5-90 200q.
The 91 200q20v (here in the states) had a 3B engine, with 20 valves, dual knock sensors, k24 turbo, and a Motronic ECU. You don't want this for a 10vt swap.
HTH!
HTH!
the 10vT doesn't have a fuel distributor anymore .. and i think it uses a different managemet . i will look into this engine this weekend
Type44QShip
01-04-2007 09:10 AM
garygbnj
09-26-2002 06:10 AM
1hot4000s
08-23-2002 07:12 PM
Ben's e//S2
07-20-2002 06:06 PM
