is white smoke always the head gasket?
Old 04-22-2004, 03:42 PM
Junior Member
nocondorfx's Avatar
Default is white smoke always the head gasket?
it smokes sometimes on take off and its getting worse
Old 04-22-2004, 04:09 PM
YucatanAudi's Avatar
Default Are you losing coolant? Have to refill often? Is it under high pressure?
White smoke is water being "burned". Blown, head gasket, cracked head, cracked block.
Lots of times, it is just condensation, but you don't see that in warm weather or after the car heats up.
Water leaking into the cylinders gives you constant white smoke.
Old 04-22-2004, 04:34 PM
Junior Member
nocondorfx's Avatar
not losing coolant, and it happens when its warm out
Old 04-22-2004, 05:35 PM
|skolnick's Avatar
could be seeping
Old 04-22-2004, 06:50 PM
YumyJager's Avatar
Does the smoke smell sweet? Like burnt caramel?
Old 04-22-2004, 10:15 PM
teabagger's Avatar
Default bad spark plugs, plug wires....
If you're not overheating it's probably not the headgasket or cyl. walls.
Old 04-22-2004, 10:31 PM
Junior Member
nocondorfx's Avatar
i am not overheating ever
Old 04-22-2004, 11:30 PM
|skolnick's Avatar
I say seeping. I bet you have the occasional hot start problem?
Old 04-23-2004, 07:35 AM
Junior Member
nocondorfx's Avatar
Default what is this hot start problem? i only get smoke coming out on take off usually, i know its not oil
atleast though
Old 04-23-2004, 07:36 AM
YumyJager's Avatar
WHAT DOES THE SMOKE SMELL LIKE
Quick Reply: is white smoke always the head gasket?
