who has done the AC retrofit kit?
#13
It dosen't include the Viton O-rings needed and then you should replace the dryer, the o-tube, flush the system, deal with numerous leaks.
I responed to your post above but I ended up swaping out everything but the evaporator.
#19
Do you detect the sarcasm?
I can tell you from first hand experience that retrofitting this particular system to R134a results in better performance than the baselines in the Audi repair manual for R12.
You can do what you want with your efficiency theories - I'll go with my cold AC filled with cheap refrigerant.
#20
bought a rebuild compressor from Hancock industries, replaced the orifice tube and the orings, replaced the receiver dryer, installed a used condenser, vacuumed the system with a compressor driven vacuum for 30 min ( high and low side), installed about 3 small cans of 134 with oil/sealer and have 38F air coming out of my vents with CC head set to "Lo"...that was about a month ago...
The _only_ way someone can convince me that R12 is better is for me to do a side by side comparison on the same car...any other comparison is apples vs oranges - if your system is marginal, you AC isn't going to perform optimally.
PERIOD.
PERIOD.
synth3mesc
04-01-2006 06:30 PM
a4nikka
03-13-2004 07:17 AM
