will these work on B4 audi 90s?
UUC short shifter
I already have Billzcat1 short shift kit and it works very good, I was just wonder if anyone has used one of these? I havent looked into it to see if its the proper length and what not, just kinda curious.<ul><li><a href="http://www.4induktion.com/uuc.html#b1">Shorty</a></li></ul>
modify to fit?? Maybe, but you'd need a bunch of OE A4 hardware and even then you're still not guarunteed that the shifter placement relative to transmission is the same between 90 & A4.
IMO you/we're better off with either the Blitzcat/Ubernugen/DIY short shifter and then modifiying it with the sealed, lubricated, zero-slip aircraft U-joints that 1PO90 always writes aboot. I really really wanna set that system up & feel what i've been missin'
check yah later
check yah later
those pieces are awefully nice with the integrated "bushless" u-joint, but it wouldn't work without some custom modification to your linkage.
Besides, since you are getting the 5-cylinder turbo and an S2/RS2 01E 6-gang, your Billzcat SS will work fine with the tranny and linkage. ;-)
Hokie - STI avant
03-31-2005 11:26 PM
Reggie
31
11-23-2004 07:50 AM
wavemanz
10-24-2004 02:48 PM
