winter tires for 90Q
I'm looking to get winter tires for my 88 90Q. Manual and sticker on the car shows 175/70/14 as being the winter tire size, but when I go on a tire size calculator, it shows a 1.9% variance from the stock 195/60/14 size. If I try a 175/65/14, the variance is only 1.2% and 175/65/14 seems to be more common than 175/70/14.
As far as I'm concerned, I would go with the 175/65/14, but there must be a reason the manufacturer set 175/70/14 as the recommended size. Any input is appreciated. TIA!
...and you'll easily get 2+ seasons out of them (Most Blizzaks on the other hand you're lucky to get more than 1 season out of them).
and back in the '80s, higher sidewall tires were more common.
Go with whatever give you the best ratio and you feel your money is best spent on. Speedo is calibrated for the error between 195/60r14 and 175/70r14... either way it's a little 'off'.
You will get slightly better fuel economy with the 70 series tire, and a softer sidewall, which can be beneficial in the winter.
LoveV8
11-21-2008 12:28 PM
dtompsett
11-02-2004 10:40 AM
vkassardjian
10-19-2000 08:35 AM
