Wiring in the engine bay?
anyone one got any sorts of reference to a wiring diagram on a 93 90CS? (or at least which connector is used on what sensor) this would be greatly apriciated, i'm having some pretty color wiring connector nightmares.... i tried STFA and didnt c anything :-(
i need to figure this out before next weekend... :-(
like the bracket on the fire wall that has 6 (i think its 6 or 5 :-? ) colored connectors held in place i need to know which color is responsible for what connector... if i could get a picture of those connectors and maybe someone to label which one is which, that would be awesome! Thank You :-)
<IMG SRC="http://pictureposter.audiworld.com/42983/93_90enginebay.jpg">
<b>1 - Harness connectors:</b>
A - For Oxygen Sensor (O2S) heater -Z19-
Heater for heated oxygen sensor -G39-, right bank
Black 2-pin connector
B - For Ignition coils
Battery positive voltage (B+) supply
White connector
C - For Heated Oxygen Sensor (HO2S) -G39-
Signal wire
Under connector holder on bulkhead
D - For Knock Sensor (KS) 1 -G61-
Blue connector
E - For Engine Speed (RPM) sensor -G28-
Gray connector
F - For Crankshaft Position (CKP) sensor -G4-
Black connector
<b>2 - Power output stage -N122- </b>
For ignition coils
A - Signal wires
From Engine Control Module (ECM)
Brown 4-pin connector
B - Ignition coil primary circuit connections
<b>3 - Throttle Position (TP) sensor -G69-</b>
With integrated Closed Throttle Position (CTP) switch -F60-
<b>4 - EGR temperature sensor -G98-
US vehicles only </b>
<b>5 - Harness connectors: </b>
A - For Heated Oxygen Sensor 2 -G108-
Signal wire
B - For Oxygen Sensor (O2S) 2 heater -Z28-
Heater for heated oxygen sensor 2 -G108-, left bank
C - For Knock Sensor (KS) 2 -G66-
Green connector
<b>6 - Data Link Connector (DLC) </b>
<b>7 - Camshaft Position (CMP) sensor -G40-</b>
White connector
Signal wire
Blue connector
Gray connector
Black connector
For ignition coils
A - Signal wires
Signal wire
Green connector
