Yuck!
Old 06-03-2004, 08:08 AM
ACaudi's Avatar
Default Yuck!
I've noticed my car has been leaking quite a lot of oil lately so I took off the underpanel to take a look. Why would oil be all over the passenger side cat? I'm thinking it's just from the oil in the belly pan blowing on to it (?)
I can't find any leaks after degreasing everything, so I guess I'm going to have to dig deeper.... any ideas?
<img src="http://pictureposter.audiworld.com/33695/img_0610.jpg">
Old 06-03-2004, 08:16 AM
YucatanAudi's Avatar
Valve cover gaskets? Oil pan gasket?
Old 06-03-2004, 08:23 AM
SCarGo02's Avatar
Default My '93 suffered from the same problem until I replaced...
...a lot of the gaskets (valley pan, valve cover, cam shaft seal, intake), and re-torqued the head bolts. Oil was dripping down the back of the engine, then at highway speed was blowing back over the tranny onto the cats.
Old 06-03-2004, 08:39 AM
Member
white90+hibredS4's Avatar
Default if you hoist the car up or just look under while its running see where it comes from...
it will probably be near the oil pan under passenger. If it is then its a pain to fix. You could try those oil sealers?
Old 06-03-2004, 08:40 AM
Member
what kind of converter is your driver side one?
Old 06-03-2004, 09:17 AM
Nkugs90's Avatar
Default Could possibly be your flange seals on the tranny...
but in addition to that there is probably a motor oil leak elsewhere.
SCarGo02's Avatar
Default The earlier the 12V was made, the more it leaks...
...best option would be to replace all gaskets (head/valve cover/valley pan/both oil pan/intake/etc...).
Click the link to see what I did, which helped a lot.<ul><li><a href="https://forums.audiworld.com/9080/msgs/126088.phtml">What I did...</a></li></ul>
Old 06-03-2004, 09:49 AM
New Member
mityVR6's Avatar
Default A valve cover gasket and a breather hose were leaking on my
'93 90 when I bought it. Might check those.
Old 06-03-2004, 10:31 AM
ACaudi's Avatar
some generic one... i'm going to replace both of them with catco's i think
Old 06-03-2004, 01:27 PM
SCarGo02's Avatar
Yup, those hoses like to get brittle over time.
radron26
08-02-2007 06:05 AM
kanefire222
12
12-19-2006 09:33 AM
Beemer832
30v V6 Discussion
03-04-2006 07:44 PM
lonestarA4
12v V6 Discussion
07-09-2004 05:07 PM
RKA
21
03-15-2004 02:34 PM
Quick Reply: Yuck!
