When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
I got a 2012 Ai for my daughter and was using OBD11 to set the DRLs to always on.
I then got a message on the dash " Headlight Range Control Defective."
I had previously had this message on my A6, si I tried the same fix using OBD11, as follows:
Headlight Regulation, Basic Settings, Basic Headlamp Setting, Start, (then wait 5 seconds) Stop.
Acknowlwdge Basic Setting, Start, (then wait 5 seconds), Stop.
Clear Error Codes and all should be good.
While it worked perfectly on the A6, it does not do so on the A1.
I have attached screenshots:
