A2 problems..Rear hatch open/close sensor pls help
Hi!
I have two indications on my dashboard saying that 1) The brake pads are worn, and 2) the rear hatch is open, when it is actually shut!
How can I fix these problems, and if it is the sensor in the rear hatch, how and where can I find it to check it?
Are the pads worn, or could it also be sensor/connection damage?
Best regards Boerge
Best regards Boerge
The sensor for the boot lid is inside the boot lock, if you take the trim off the boot lid so you can see the lock you'll see a two pin conection to the boot lock disconect this, with it disconected it should show the boot closed if you bridged the conection it would show the boot open.
The pads are easy to see if they are worn or not, if the have been changed it's possible that the pad sensor conection has been broken on the car side rather than the pad side, if so this conector only comes with ABS loom molded in and requires splicing in to the car loom
freinando
A6 (C7 Platform) Discussion
03-29-2018 04:50 PM
Quattro_Denver
05-18-2007 06:29 AM
