Last edit by: IB Advertising
- Audi A3 How to Replace Ball Joints<br>Step by step instructions for do-it-yourself repairs.
** GruvenParts.com Billet Head Flanges (NOT CAST!) -- Choose Your Configuration !
![](http://cdn1.bigcommerce.com/n-ww20x/lyr7tp5r/products/152/images/434/progress_resized__97970.1430328369.1280.1280.jpg?c=2)
Billet VW/Audi 1.8T Billet Coolant Head Flanges -- NOW IN STOCK !
GruvenParts.com is happy to release these VW/Audi Billet 1.8T Coolant Head Flanges made from 6061-T651 aluminum and professionally tig welded and 100% pressure tested. This billet aluminum version replaces the crack prone plastic 1.8T head coolant flange P/N 06A-121-132-AP, and is also interchangeable with 06A-121-133-BB, 06A-121-133-J, 06A-121-132-D, 06A-121-132-G, 06A-121-132-Q. (06A121132AP, 06A121133BB, 06A121133J, 06A121132D, 06A121132G, 06A121132Q). This part fits all 2000-2006 Audi TT w/1.8T engine and all 2000-2007 VW Golf/Jetta/337/20AE/GLI with 1.8T engine.
THESE ARE NOT WEAK, POROUS CHINESE CASTINGS ! THESE ARE HOGGED OUT FROM WROUGHT AEROSPACE GRADE 6061-T651 BLOCK !!
This part is machined in house like everything else we make (not in China) using one of our 4 axis CNC HAAS milling centers. This part ships with a new Viton base O-ring preinstalled. Just add your coolant temp sensor and bolt it up! We're so sure this will eliminate your crack prone head flange, this part comes with a LIFETIME WARRANTY.
Options for this part include deleting the heater core outlet, oil cooler outlet, or both.
And dont forget to also check out our popular billet 1.8T upper radiator hose 4Y and the billet 3Y.
![](http://cdn1.bigcommerce.com/n-ww20x/lyr7tp5r/products/100/images/293/1018__01825.1381858648.1280.1280.jpg)
Billet 1.8T / 1.9TDI / 2.0 Upper Radiator Hose 4Y!
GruvenParts.com is proud to announce the release of our new BILLET VW/Audi 1.8T / 1.9T / 2.0 Upper Radiator Hose 4Y Pipe to replace the OEM Audi/VW plastic 4Y P/N 1J0-121-087C (1J0121087C)
This part is found in OEM upper radiator hose P/N’s
1J0-122-101BL (1J0122101BL),
1J0-122-101R (1J0122101R),
1J0-122-101A (1J0122101A),
1J0-122-101B (1J0122101B),
8NO-122-101A (8NO122101A),
8N0-122-101B (8NO122101B)
GruvenParts.com VW Golf/Jetta and Audi TT 1.8T Coolant Fitting P/N 1J0-122-109AQ
GruvenParts.com is pleased to announce the release of our MKIV VW Golf/Jetta 1.8T and Audi TT MK1 1.8T Billet Y Pipe made from aircraft grade stainless steel to replace the cheap plastic OEM fitting found on hose P/N 1J0-122-109AQ (1J0122109AQ).
"![](http://cdn1.bigcommerce.com/n-ww20x/lyr7tp5r/products/96/images/402/R32_Rear_Control_Arms__43955.1412388092.1280.1280.JPG?c=2)
TT/R32 Rear Adjustable Control Arms
Click on the picture to visit our product page for up to date pricing info.
CHOOSE POLY-BUSHINGS OR SPHERICAL ROD ENDS !!
Got a lowered TT or R32 ? Then you already know how the camber and toe become completely out of sorts, causing poor handling and expensive tire wear the more its lowered.
The GruvenParts adjustable control arms allow for complete rear wheel alignment and feature the following :
Choose from a zero deflection high radial load PTFE lined inboard spherical joint with protective dust boots preinstalled over specially machined bushings. The fit of the boot over the spherical joint and bushings is nearly water tight!
OR
A poly bushing inboard end made from heat treated 4340 forged chromoly housing, thread in grease fitting, zinc plated steel protective sleeves, and race grade greaseable black polyurethane bushings from Energy Suspension.
You decide which set up you want ! The zero deflection spherical joints are suited for serious track abuse while the poly bushing ends are better suited for daily drivers.
All GruvenParts control arms feature the following :
Super strong, heat treated 4340 aircraft grade chromoly rod and ¼” thick U-Joints with machined, internally lubricated (molybdenum disulfide) threads. No weak aluminum is used for these parts (aluminum threads wont hold up).
Distinct proper wrench adjustment flats machined into the bars which allow for 2” of length adjustment while on the car. There is no knurled hand adjustment nonsense here, ours are simple to adjust.
Thick, durable powder coat finish (and zinc plating on the poly bushing ends) in your choice of high gloss black or Bilstein jazz blue.
Made right here in Atlanta, Georgia by our FAA approved commercial aviation machine shop working on state of the art CNC mills and lathes. You wont find many shops working at our level, and you wont find higher quality anywhere !
We know the economy is tough right now, so we are offering these at prices well under our competition. Buy 2 sets and save !!!
This product fits Audi TT (2001-2006), Audi A3/S3, VW R32 (2004), VW Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant and replaces P/N 1J0-505-323L (1J0505323L) and 1J0-505-323N (1J0505323N).
***Save Big $ when buying these in conjunction with our Adjustable Rear Swaybar End Links and our Adjustable Front Swaybar End Links
...And finally...
![](http://cdn1.bigcommerce.com/n-ww20x/lyr7tp5r/products/133/images/334/the_one_Copy__96840.1398475197.1280.1280.JPG?c=2)
TT/R32 Rear Adjustable Control Arm Hardware
Need to buy 1 off’s for a project? Want new/longer fasteners? Look below for the parts to get the job done!
- High radial load GENUINE FK JMX Series PTFE lined heim joint kits
- Custom 4340 Forged, Heat Treated poly bushing ends with Rolled Threads
- Racing Grade protective rubber dust boots for ¾” heim joints
- Longer bolt kits - 80mm in length, grade 8.8, zinc plated
- Headlight Leveling System Bracket
![](http://cdn1.bigcommerce.com/n-ww20x/lyr7tp5r/products/139/images/389/R32_Front_Swaybar__28648.1405109459.1280.1280.JPG?c=2)
GruvenParts Billet R32/TT Adjustable Front Swaybar Endlinks !
GruvenParts.com is happy to release these Billet Front Adjustable Swaybar End Link sets for the Audi TT MK1 and VW MK4 R32.
We start with a center body made from 6061-T651 aircraft grade Aluminum hex to replace the flimsy non-adjustable OEM spaghetti links. We then add super strong 6,000 lbs radial load capacity sealed ball joints on either end to provide many years of noise free operation. Our ball joints have a built in dust boots to seal out the elements and do not require any maintenance. If they ever do need to be replaced, they can bought seperately on our site. These linkages will not deflect under the hardest track corners and will provide the most accurate handling.
All center sections are powder coated with a thick layer of either Gloss Black or Bilstein Jazz Blue - please choose during check out.
Our design allows simple and quick adjustment on the car. Simply loosen the jam nuts at either end and spin the center body portion to lengthen or shorten, then retighten the jam nuts.
This adjustable design will provide +/- 1 inch of adjustment on the car, which is enough to handle all lowered (or raised) set ups. You want the stabilizer bar end links to be as vertical as possible, perpendicular to the swaybar itself to avoid any loading in the fwd/aft direction.
Applications :
This product comes as a set of 2 endlinks and replaces OEM P/N's 1J0-411-315D (1J0411315D) and 1J0-411-316D (1J0411316D) found on the following vehicles and possibly other makes, please verify your OEM part numbers match these listed :
[b]1999-2006 Audi TT MK1 (all)
2004 VW R32 (all)
![](http://cdn1.bigcommerce.com/n-ww20x/lyr7tp5r/products/97/images/401/IMG_0850__10450.1412385108.1280.1280.JPG?c=2)
GruvenParts Billet R32/TT Adjustable Rear Swaybar Endlinks !
Got a lowered TT MK1 or R32 MKIV ? Then you need to be able to adjust your rear stabilizer bar end links to ensure the linkages ride perpendicular to the sway bar and correct the less than ideal handling typical of lowered set ups. The factory set up does not provide any adjustability in the sway bar end links but GruvenParts.com has you covered!
We’re proud to release these adjustable rear stabilizer bar end links with FORGED high strength steel lower bushing ends with rolled (not cut!) threads, and high strength fully sealed upper tie rod ends. The center bodies are custom machined from STAINLESS hex in house and then powder coated beautiful gloss black or Bilstein jazz blue to match our Adjustable Rear Control Arms and our Adjustable Front Sway Bar End Links.
These come ready to install and are pre-greased with special polyurethane grease and include a new lock nut on the top joint. Please re-use your existing lower OEM bolt when installing these adjustable units.
These are sold in sets of 2, enough for 1 vehicle.
This product fits Audi TT (2001-2006), Audi A3/S3, VW MKIV R32 (2004), Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant and replaces OEM linkage P/N 1J0505466B.
Save Big $ when buying these in conjunction with our Adjustable Rear Control Arms and our Adjustable Front Swaybar End Links
OR
...And finally...
Applications :
2004 VW R32 (all)
Billet VW/Audi 24V 2.8/3.2/3.6L Oil Filter Housing Caps !
Modular Billet Aluminum Oil Filter Housings For VW And Audi 24V 2.8/3.2/3.6L Engines !
This product is intended to replace VW/Audi Part Number 071-115-433 (071115433). Please check the OEM part number of your oil filter housing cap before ordering. You can do this easily by calling your dealer and giving them your VIN # and asking them to tell you the part number for your oil filter housing cap.
Just like our best selling billet MK2/MK3/MK4 VR6 and 4.2L V8 oil filter housing caps -- This one was worth the wait ! Never, but NEVER break a flimsy plastic oil filter housing again. Or deal with the unsightly leaks created by the cheaply made (yet expensive) plastic OEM housing cracking and deflecting. We made this one the way VW and Audi should have – from A SOLID BLOCK OF ALUMINUM, by God!
First, we start with a massive solid chunk of Aircraft Grade 6061-T6511 Aluminum. The section is delicately placed on one of our special CNC machining centers and precision cut to EXACTLY match the OEM plastic housing. The metal gods (well, in this case, one of our highly talented CNC programmers) has programmed elaborate steps for the very time consuming and expensive operation of profiling the special buttress threads into the housing using the exact DIN spec thread cutting tool required for a perfect seal.
This part comes with 2 threaded holes (M10x1) with steel drain plugs installed in both as shown in the pictures. You can therefore choose to install a VDO pressure sender in the center hole (VDO P/N 360 015) and/or a VDO temperature sender in either the outboard threaded hole or center threaded hole (VDO P/N 323 423). Please note the pressure sender will only fit in the center hole due to its size. Either hole can be retained as a drain. Please note the temperature and pressure senders are not included, you can source those from many retailers (such as Summit Racing). This DOES include the 2 steel drain plugs.
This product is intended to replace VW/Audi Part Numbers 071-115-433 (071115433) or equivalent. Please check the OEM part number of your oil filter housing cap before ordering. You can do this easily by calling your dealer and giving them your VIN #.
Application Guide :
Audi A3 8P All 3.2L
Audi A3 8P All V6 3.2L
Audi TT MKI All 3.2L
Audi TT MKII All 3.2L
Volkswagen CC 4Motion VR6
Volkswagen CC FWD VR6
Volkswagen Eurovan T4 All VR6 24v
Volkswagen Golf IV All VR6 24v
Volkswagen Jetta IV All VR6 24v
Volkswagen Passat B6 All 3.6L
Volkswagen R32 MKIV All All
Volkswagen R32 MKV All All
Special Note At The End :
You will need to carefully remove the sping bypass valve located at the base of your OEM plastic oil filter cap and install it into this billet housing cap. Carefully push down on the bypass valve inside your OEM cap and deflect the spring to 1 side fully. The whole bypass valve will then unclip from the plastic OEM cap. Install it in the same position into our billet cap. It is easiest to do this on a work bench, just use a suitable deep well socket to fit against the spring bypass valve, face the cap down (bowl at top) while aligning the bypass valve with the metal tangs on our billet housing. Then apply about 10 lbs of force downward while wiggling side to side gently. Your existing bypass valve will snap into place over the metal tangs in our housing. YOU MUST INSTALL THE BYPASS VALVE. If you do not, the oil will simply bypass the filter and will not be cleaned.
When installing this cap into the oil filter housing, please clean all threads and use a bit of anti-seize on the threads of our part to make this easier to remove during your next oil change. Also, be sure to lubricate the o-ring with some fresh oil so it is not torn during installation. This part doesnt come with the O-ring -- that comes with the filter itself.
"![](http://cdn1.bigcommerce.com/n-ww20x/lyr7tp5r/products/140/images/400/with_filter__24697.1412384091.1280.1280.JPG?c=2)
Modular Billet Aluminum Oil Filter Housings For VW And Audi 24V 2.8/3.2/3.6L Engines ! (shown with optional filter/o-ring installed)
GruvenParts.com builds bulletproof Hardware for your VW/Audi !!
![](http://cdn1.bigcommerce.com/n-ww20x/lyr7tp5r/product_images/theme_images/slide7__78572.png)
Click Here to Visit GruvenParts.com !
Anyone interested in a new BILSTEIN PSS9 coil over kit?
It's for an Audi TT if you own one of these vehicles and your looking hit me back.
Kit is completely new. I had to get rid of my Audi due to engine issues and now I'm stuck with a complete new kit.
They are awesome coils, I have the same on my Corrado and love them!!!
