2.0T Stutter
Hello,
last night coming from work on freeway all sudden my CEL starts flashing, and when i step on throttle engine stutters. I was able to make it home by barely touching the throttle. next i did full Autoscan see below. I gave P0304 Code, and engine shaking. so so far I have tried swapping Ignition coils from 1 to 4,2-4,3-4 and same code P0304. Usually all we read about is the ignition coil going bad. in this case it is not. what could be causing this? I have looked around the connector for COP #4 all wires, and connections look good, no bend tabs. also we read about carbon build up giving a code for random misfire, yes, and i have had this code pretty much since I bought the car, but motor has never stuttered like this. this is actual stutter motor shaking, running on 3 cylinders. I recently did the sparks plugs, used OEM plugs. i did pull plug on 4 to inspect looks normal.
Monday,24,September,2018,09:06:27:43295
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.2.1.5 (x64) HEX-V2 CB: 0.4411.4
Data version: 20180518 DS287.2
www.Ross-Tech.com
VIN: WVWUK73C08P051382 License Plate:
Mileage: 134460km-83549mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 52 53 56 62 65 72
VIN: WVWUK73C08P051382 Mileage: 134460km-83549miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 3C0 907 115 S HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWZCZ000000000
Coding: 0404010A18070160
Shop #: WSC 00028 028 00001
VCID: 3039EE51D629C277C14-8064
2 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 134465 km
Time Indication: 0
Date: 2018.09.24
Time: 08:59:57
Freeze Frame:
RPM: 1198 /min
Load: 23.1 %
Speed: 0.0 km/h
Temperature: 27.0°C
Temperature: 12.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.478 V
000772 - Cylinder 4
P0304 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 134465 km
Time Indication: 0
Date: 2018.09.24
Time: 08:59:57
Freeze Frame:
RPM: 1198 /min
Load: 23.1 %
Speed: 0.0 km/h
Temperature: 27.0°C
Temperature: 12.0°C
Voltage: 14.478 V
Readiness: 0110 0101
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 D HW: 3C0 614 109 D
Component: J104 C4 440 V2 0003
Revision: --020--- Serial number: 00000776088981
Coding: 0000345
VCID: 1F1B1DEDBBB74D0F68E-804A
No fault code found.
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 1K0 820 047 GF HW: 1K0 820 047 GF
Component: Climatic PQ35 141 0909
Revision: 00141027 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 6E8530290C9D9487938-803A
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000005113356
Coding: 10840F0340041A28470000000F000000000859435C00010000 0000000000
VCID: 71BF2B551DA38B7F8EA-8024
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 020807 003 0205
Coding: 00046997
Shop #: WSC 00028
2 Faults Found:
00987 - Lamp for Brake Light; Left (M9)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00111100
Fault Priority: 1
Fault Frequency: 5
Reset counter: 111
Mileage: 133661 km
Time Indication: 0
Date: 2018.08.30
Time: 03:39:00
Freeze Frame:
ON
Voltage: 14.15 V
ON
ON
OFF
OFF
ON
02395 - Parking Light Front Right (M3)
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 74
Mileage: 133581 km
Time Indication: 0
Date: 2018.08.26
Time: 14:31:00
Freeze Frame:
ON
Voltage: 14.25 V
ON
ON
OFF
OFF
ON
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 N HW: 3C0 909 605 N
Component: 17 AIRBAG VW8R 032 2522
Revision: 13032000 Serial number: 003B2PJWXZXL
Coding: 0012599
VCID: 313FEB55DD23CB7FCEA-8064
Subsystem 1 - Part No: 3C0 959 339 B
Component: BF-Gewichtsens. 007 0003
Subsystem 2 - Serial number: 0000000003NQKC
Subsystem 3 - Serial number: 0001.01.000000700000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332MSME165A056AEÿ†63
Subsystem 5 - Serial number: A056AEÿ†6342MSME16731B5FLÿ†63
Subsystem 6 - Serial number: 31B5FLÿ†6351HTS61CGGEOO6-ÿ†63
Subsystem 7 - Serial number: GEOO6-ÿ†6361HTS6L4I4O2579ÿ†63
Subsystem 8 - Serial number: 4O2579ÿ†63727TS61CGS87V6Pÿ†63
Subsystem 9 - Serial number: S87V6Pÿ†63827TS61CGS0A67/ÿ
Subsystem 10 - Serial number: S0A67/ÿ
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 L HW: 3C0 953 549 L
Component: Lenksäulenmodul 006 0010
Revision: 00006000 Serial number: 3C5953507BK
Coding: 0000013
VCID: 3537DF45294BE75F922-8060
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 971 F HW: 3C0 920 971 F
Component: KOMBIINSTRUMENT VD1 1216
Revision: V0002000 Serial number: 00000000000000
Coding: 0007205
VCID: 28090631EEF98AB7194-807C
Address 19: CAN Gateway Labels:. 3C0-907-530-V2.clb
Part No SW: 3C0 907 530 E HW: 3C0 907 951
Component: J533__Gateway H10 0080
Revision: H10 Serial number: 1200P078310302
Coding: F9807F070012021002
VCID: 2313111D97DF69EF4C6-8076
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 3C0 919 965 HW: 3C0 919 965
Component: Kompass 005 0003
Revision: 00005000 Serial number: 1166279TRTRJ06
VCID: 6D873725019B6F9FAA2-8038
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 AK HW: 3C0 959 433 AK
Component: IMMO 051 0383
Revision: 00051000 Serial number: VWZCZ000000000
Shop #: WSC 61689 001 1048576
VCID: 73B3215D67BFB96F7C6-8026
Subsystem 1 - Part No: 3C0 905 861 J
Component: ELV 029 0380
3C0905861J ELV 029 0380
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1131
Revision: 32008001 Serial number: 00000043278919
Coding: 0001205
VCID: 3B23C97D0F6F312F646-806E
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.134 H08 1901
Address 46: Central Conv. Labels:. 3C0-959-433-46.clb
Component: KSG PQ46 RDK 051 0221
Coding: 13910F8001862E521004141FF08A0F0E085C00
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1131
Revision: 32008001 Serial number: 00000634978919
Coding: 0001204
VCID: 3C21CA610A6136176DC-8068
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
Component: J540 EPB3 VW-09393 0009
Revision: 008 Serial number: 00000000169747
Coding: 0000057
VCID: 290F0335F5F3B3BF06A-807C
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 C HW: 1K0 035 161 C
Component: Radio DE2 014 0019
Revision: 00014000 Serial number: VWZ4Z7G6288508
Coding: 0040402
2 Faults Found:
00856 - Radio Antenna
011 - Open Circuit
00857 - CD Changer Unit (R41)
004 - No Signal/Communication
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1118
Revision: 12006001 Serial number: 00000002365049
Coding: 0001168
VCID: 3E25C0691C7D2407438-806A
Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
Component: RDK 0450
Coding: 0100101
Shop #: WSC 131071 1023 2097151
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1118
Revision: 12006001 Serial number: 00000002374822
Coding: 0001168
VCID: 3FDBBD6D1B772D0F48E-806A
End----------(Elapsed Time: 01:22, VBatt start/end: 14.5V/14.5V)-----------
www.Ross-Tech.com
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 134465 km
Time Indication: 0
Date: 2018.09.24
Time: 08:59:57
Freeze Frame:
RPM: 1198 /min
Load: 23.1 %
Speed: 0.0 km/h
Temperature: 27.0°C
Temperature: 12.0°C
Voltage: 14.478 V
000772 - Cylinder 4
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 134465 km
Time Indication: 0
Date: 2018.09.24
Time: 08:59:57
Freeze Frame:
RPM: 1198 /min
Load: 23.1 %
Speed: 0.0 km/h
Temperature: 27.0°C
Temperature: 12.0°C
Voltage: 14.478 V
Coding: 0000345
Coding: 00046997
Shop #: WSC 00028
2 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 5
Reset counter: 111
Mileage: 133661 km
Time Indication: 0
Date: 2018.08.30
Time: 03:39:00
Freeze Frame:
ON
Voltage: 14.15 V
ON
ON
OFF
OFF
ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 74
Mileage: 133581 km
Time Indication: 0
Date: 2018.08.26
Time: 14:31:00
Freeze Frame:
ON
Voltage: 14.25 V
ON
ON
OFF
OFF
ON
Coding: 0012599
Coding: 0000013
Coding: 0007205
Coding: 0001205
Coding: 0001204
Coding: 0000057
Coding: 0040402
2 Faults Found:
011 - Open Circuit
Coding: 0001168
Component: RDK 0450
Coding: 0100101
Coding: 0001168
I wish I'd been more proactive and read up on the ignition coil issue. I had a coil go bad and would suffer engine stutter under brisk acceleration, from low RPM's. Dealer took care of it and charged me more than double than I would have paid for a replacement coil and DIY swap-in.
rikapple
05-24-2018 03:24 PM
