2009 Audi A3 2.0t Quattro - Mechatronic Unit Problems
So I recently bought an 09 A3 with known trans problems, in limp mode, etc. I got it for dirt cheap and would be fine with slapping a used trans in it if I have to. I used vcds and found a code like “Lost communication with transmission control unit.” So I unplugged the connector on top the trans under the airbox and found DSG fluid sitting in the connector. I cleaned it out to bone dry and cleared codes. It drove like a champ, 500 miles later, went into limp mode again, cleaned it out again, cleared codes and its driving fine. I haven’t driven it since, needs a mechatronic/valve body, since the connector is attached to it. It is leaking thru the connector/pins not the outside. I have a used mech unit from a 2010 VW Jetta, same trans. My part code for my valve body is 02E325025AMZCK, the jetta’s part code is 02E325025ATZF3. My part code has been superseded like 4 times to 02E325025ATZ3Q. So the newest one and my used one have the same part number besides the last 3 which is the color code. They look exactly the same. You think if I slap the Jetta Mech unit(same trans code) in and code it right it would be good to go if this one doesn’t leak either?
Thanks
Hunter
Thanks
Hunter
rcollins2867
11
02-08-2023 11:45 AM
